I'm trying to build a system for the first time so I'm kinda not very experienced. I have picked a GPU I am willing to pay for. at most I will pay is 380$ (trying to save money) : The EVGA GTX 670 is the ideal card I have picked for Nvidia. The problem is that when I look on sites to see benchmarks comparisons etc. I find that it is always different on two different sites. Like one site's forum will say that the 670 is great cause it will be future proof and cuda so WINNING! Where as other sites will say oh no you can overclock the 7950 to way over the performance of a 670 no problem but never specify which vendor. I do want to get the most for my money but at the same time I just can't seem to find a card at the same price that is AMD and is better. So I guess this is my question: Which AMD card is the equal counter-part to the 670 on AMD's side. Final note: I'm not going to overclock the GPU because I am already OCing the CPU.
On new egg I've only seen ones as low as 390-560$ and I know I'm going to come off as cheep here but I'm basically searching my couch for pocket change to pay for this system now, I'm all but finished with it however. Thankfully
Video card are excellent at chucking there heat out the back of your case....you wont see a huge case temp increase with overclocking a GPU and any that you do see can normal be ofset with the cards software fan profiles in the overclocking software.
If your gaming the 7950 with a overclock will murder a 670
