</p>
This is one insanely fast card. Check out the video to see how it runs at 4K and 1080p.
Where to buy:
Specs from EVGA:
Performance
NVIDIA GTX 980 Ti
2816 CUDA Cores
1102 MHz Base Clock
1190 MHz Boost Clock
194GT/s Texture Fill Rate
Memory
6144 MB, 384 bit GDDR5
7010 MHz (effective)
336.5 GB/s Memory Bandwidth
Interface
PCI-E 3.0 16x
DVI-I, DisplayPort, DisplayPort, DisplayPort, HDMI
Resolution & Refresh
Max Monitors Supported: 4
240Hz Max Refresh Rate
Max Analog : 2048x1536
Max Digital : 4096x2160
Dimensions
Height: 4.376in - 111.15mm
Length: 10.5in - 266.7mm
Width: Dual Slot
Test Rig:
- ASRock X99 WS
- Intel i7 5960x
- 64GB Corsair DDR4
- Corsair 1TB SSD
- Samsung 256 GB m.2
- Fractal Define R5
- Corsair 1000W PSU
This is a companion discussion topic for the original entry at https://teksyndicate.com/videos/evga-980ti-sc-overclocked-4k-benchmarks-review
