This can’t be real right? I’ve even added a monitor to it and kept the covers on the other ports since I’ve had it.
Let me back up.
I have a 970, and having just gotten a Valve Index found out that 2/3 of the display port ports aren’t working, and probably the HDMI too. If I want to VR I have to disconnect my main monitor and put the headset in that exact port. When I plug the VR or monitor into another port it seems to recognize something’s there but can’t display to it. Even display settings shows 2 monitors if it’s in another port, I can move my mouse through it but it didn’t take the desktop icons back from the second monitor. I have gone through a clean install of my display driver with DDU and no dice.
I see no reason this is actually real. Is there some kind of deep sleep for GPU ports that aren’t used? Something I can do in my UEFI? I just updated the driver when I got this VR could that have done something? Do they hate me for not installing GeForce Experience?
I have to be stupid on this, this is just too much of a weird thing to happen.
I suspect this would be better off in the windows section under software. But just to make sure the hardware is fine, go into UEFI and then try the other ports there.
Fiance’s 2070 display ports wouldn’t work until I updated the driver so the only one that worked was HDMI. So yeah Nvidia can be a bit finicky at times.
I’ve had both installed when I restarted, and separately plugged the Index in while already booted, no dice. I’m on the latest driver for the 970s, even through a clean install, and it doesn’t work.
There has to been some kind of state where it said ‘oh these ports are used, keep them active’ and turned off the rest. If that’s a thing. There has to be something to this instead of being crazy lucky I plugged my newer monitor into the only working DP port out of three.
