Hello, i have a Radeon HD 7770, every miner i have tried to install crashs on startup. I have tried GUIMiner, Reaper and cgminer and no luck.
Anyone know what i can do?
- Josh
- Josh
you can post this in a relivant thread.
Such as?
Because you said reaper I am assuming you are trying to do litecoin.If not you should consider switching to it.
Try using this but you have to turn off stratum or it will not work.
If this will not show up you have to delete C:\Users\You\AppData\Roaming\poclbm\poclbm-scrypt.ini
