I am looking into using the Evercool EC-DF001 17.72" Supports 5 PWM Fans Black Braided Cable from newegg.
link:http://www.newegg.com/Product/Product.aspx?Item=N82E16812311001&cm_re=five_fan_pwm_cable--12-311-001--Product
I am just curious an can't seem to find it online if this cable just works from the fan pwm header or the 4 pin molex cable I ask because I can use both as needed but just don't know.
thank you an I hope this is a honest question worth asking and not wasting space.
I found this :
http://www.evercool.com.tw/categories/global/cables/fancablesadapters/ec-df001/ec_df001.php
I'm looking for a similar product but I need 3 fans to get the PWM signal.
Edit: Read it again, the first fan gives the feedback, all get PWM control.
thank you it was helpful now I have to change me search.
if it helps pwm can not have many fans on one header I found out thru this site you shared.
The cable you posted does the following :
Control using PWM and give power to up to 5 fans but using the RPM of just one fan to feed back to your BIOS.
If you have 5 similar fans it will be no problem.
