Hey guys, I'm using an ethernet powerline adapter with my 50 mb/s fibre optic. It says to plug it directly into the wall, but I have mine in a four socket extension cable. My download speeds fluctuate alot, earlier I was downloading and it went from 3mb/s to 500kb/s in about 15 seconds, then I rebooted at it went back up to 3mb/s.
My question is how much is this affecting the connection? Will i get better a connection if I buy a longer ethernet cable and put it directly into the wall instead?
Adapter: Zyxel PLA4201 v2; http://www.dabs.ie/products/zyxel-pla4201-v2-500-mbps-mini-powerline-ethernet-adaptor-pair-8Y7Q.html?src=3
Thanks
