Ethernet cable or Wireless adapter?
Which one should I get? I mean I could get a cable but I would have to run it throughout the house and my parents probably wouldn't like it (I may be able to work something out though) but then with the adapter I might not get a good strong connection :T so I'm kinda stuck here, and if I should get an adapter can you guys recommend one?
Get the ethernet cable if there is any way on earth you can make it worth -- so much better
Thanks
wireless is decent if you have a good signal but chances are if you have good signal you might as well have Ethernet you can get a cheap wireless plug for not much and you can use apps on android like WiFi analyser to see how good signal is where your pc is
look into a powerline adapter.
Agree with @Dje4321 if your house isnt old then a powerline adaptor would work allright. Ethernet cable would be the cheapest and most reliable. Wifi would be the most expensive if you dont already have goo wifi coverage.
