so i just bought these servers and looking to buy a few more eservers x335's for my home server for noob use. all will be run through linux
game server
site host
email server.
so my question is with the x335 there isnt a vga output and ive read that i would need to purchase a c2t break out cable, but it comes from china. does anyone have any recommendations on this server. thanks in advanced
nope they are a tad bit wider. (c2t cable)
just thinking about it now, im going to load the os via the other servers then place the HD on the x355. i think that might work then use putty to access.
until the cable comes and just work on the other ones directly
How do you deal with the noise?
You can use the lights-out management interface to manage it
bc its in a case and i wont be in that room
