Specs
Windows 10 home
8086K
32Gb Trident-Z RAM 3200
Strix Z370-E
1080 Ti
970 EVO 1Tb
8Tb Red Drive
So here is my issue. Couple months back I started getting critical process died errors when using/playing COD MW, Overwatch & Adobe Premier.
#1 - Re-installed my OS on the 860 EVO 1Tb I had. (Same issues as above)
#2 - Swapped M.2 slots (Same issues as above)
#3 - Installed an OS on my 8Tb Red Drive (No Issues)
#4 - RMA the 860 EVO and install OS on new drive (Same issues as above)
#5 - Bought a 970 EVO since I was planning on upgrading my wife’s laptop with a bigger drive. Now on the 970 EVO Overwatch & Premeir seam to work but COD MW now hard resets the computer (no error just shuts off). Although the first time COD crashed it BSOD with a Critical Process Died.
Unfortunately, the hard rest now means there is no dump to look at and I was stupid and forgot to save it from the earlier OS’s
Still untested Issues:
Motherboard issues
RAM issues
CPU issues
PSU issues
It’s weird that the OS on my SATA Red drive seams to be working fine? What do you think?
