Alright so about 2 weeks I started having this issue. Some websites wont load correctly or wont load at all in chrome, and IE and the reason given is ERR_CONNECTION_RESET. I believe I have updated all drivers relevant, tried resetting the router and such, I've reset both the Winsock, and TCP/IP stack. To no avail. Also it doesn't matter if I use my network card, or Ethernet cable. I am able to access the websites on another computer just fine.
What do I do next??
Windows 7 professional, 64-bit
hmm......if trouubleshoot problems doesn't work i'd do the usual clearout *cclean cache/cookies*....and doublecheck that proxy is disabled and ping sites
or just boot a distro off usb to validate the issue
outside of netsh winsock reset in cmd prompt as admin i dunno
also, using firefox. doesn't work either.
Odd one to troubleshoot as ERR_CONENECTION_RESET usually occurs when the error is unknown.
Might be an MTU issue. Used to have this issue a long time ago.
See if these help. (some more links on them)
Link 1
Link 2
If you use the "netsh winsock reset" (which needs to be run as admin) remember that it is REQUIRED to restart the machine for the changes to have effect.
