https://www.youtube.com/watch?v=yZhidWNT0CA
lol, i was thinking bfbc2 and stalker clear skys or pripriat.... and you named both of those.
btw, in bfbc2, you can open the ini file and change your field of view (so it will look right)... however its the vertical FOV, not the horizontal, but i believe there are calculators out there that can convert hfov to vfov
what would i need to change in the file?
you would go to "My Documents\BFBC2"
inside is a .ini called settings.... open this in notepad.
now use this website here to convert vertical feild of view to horisontal field of view:
http://www.rjdown.co.uk/projects/bfbc2/fovcalculator.php
you want a horisontal FOV of about 85 to 90 for a 16:9 screen, not sure about a tri screen setup
