320 Series Monitor arms -- Metal construction & GAS (not spring!) monitor arms.
Comes with Desk & through-hole grommet mount options. It supports Dual 30" monitor with ease -- 360 degree rotation so you can easily swap back and forth between portrait and landscape if you want.
75x75 and 100x100 mm VESA mounting options available.
Also compatible with iMacs that have the VESA mount option and weigh 20lbs or less.
How are these compared to the SpaceCo solutions? These are obviously much cheaper but is there a significant difference in quality that makes the SpaceCo's a better option?
This is really cool, I am not yet at the point, or have the space for a set up like these but I do plan on it in the future. Very nice review, had all the information I could ever need.
The arm I had "sags" over time. It has a very similar nut to adjust the tilt. I was having to loosen that nut, tilt the monitor back up and re tighten about once a week. No matter how tight I make it I'll notice the monitor has tilted down over a few days.
edit: to clarify, I am not talking about the arms in this video.
Bought a one-arm version end of last year for work. The one I bought was branded Ricoo here in Germany, but it seems to be a rebrand as it looks identical. haven't had any issues with, and only needed to retighten the screw for the monitor tilt once.
When I have a fitting slipping like that I will cut a washer out of EPDM or some other solid rubber gasket material with a lot of "grippyness" to it. If it not feasible to fit a washer in place sometimes belt dressing spray applied to mating surfaces works.
Nice review! So glad you're starting this workplace ergonomics series :) Currently I'm looking to get a single monitor Ergotron LX (EU, no Ergotech here) for my 27 inch Dell. Plan to switch to a 34inch ultrawide later, and I've seen it can hold those as well. If anyone has experience with other brands available in EU, please share ;)
