I would like to build an Epyc system and would like to follow the steps of others who already have; however, I simply can’t find any Epyc build guides.
Am I missing something?
Same as tr4 socket follow the threadripper guides. You need a Mobo that supports epyc but it’s the same socket
not much to find. Epyc is TR but with out any dead cores and has a slightly tweaked pin out. and the build for them is much the same aside from the ram capacity and memory lanes. 90% of the things that are true with Threadripper are the same with Epyc.
Motherboards are still very expensive and only available from a small set of vendors. However, here are a few I’ve found on YouTube:
