Hi,
can someone help me export the social media icons in this to svg icons.
They’re in a .eps file.
Thanks
Zibob
April 18, 2018, 10:14am
2
Had never heard of EPS files before. The wiki article has a list or programs that can open them, from there you should be able to re save them in another format. Sorry I don’t know much about them but looks like a good starting point.
Encapsulated PostScript (EPS) is a DSC-conforming PostScript document with additional restrictions which is intended to be usable as a graphics file format. In other words, EPS files are more-or-less self-contained, reasonably predictable PostScript documents that describe an image or drawing and can be placed within another PostScript document. Simply, an EPS file is a PostScript program, saved as a single file that includes a low-resolution preview "encapsulated" inside of it, allowing some pro...
You should be able to open them with Inkscape and save them as SVG files.
