Entry Level PC?
This is the build I cam up with that I plan on doing I'm going to run the gpu's in crossfire thats why I have the price set for $259 instead of $127 for the 7770's. If someone can improvements but keep it in the $800 price range then awesome. http://gyazo.com/a8d16d4da1ebeda11b515e60f0505746
Why 7770 crossfire over a single GPU.......do you already have a 7770?
No, I saw someone do something simular, It's not a set in stone thing, I'm thinking about using a Sappire Radeon 7950 instead
YES DO THAT!!!!!
The 7950 spanks 7770 CF and being single card has none of the drawbacks (Crossfire setup = louder, hotter, driver issues, microstutter, bla bla bla.....really only worth doing when talking about HIGH end beast rigs)
was going to recommend one of the MSI R7870 Twin Frozr as the price is about the same as you have budgeted, but the 7950 is such a good card for the money if you can spend just that little bit extra!)
you have an fm2 apu (which is pointless when you have a dgpu) and an am3+ motherboard (not a very good one at that), at that price you should be able to get an 8320, if you want to crossfire (not 7770s... anytime in the future) you will want a 990fx board
It still fits in my price range 2 7770's are only $10 cheeper than the 7950. Thanks for the help
I changed the processor for a cheaper one,
http://gyazo.com/1d84a266441da3e4c73e95a03eb3d3b9
get the Athlon 760k instead of the A10 its cheaper for the same thing.
I updated the last one
Is what I'm seeing true? 7950 maxing out crysis 3 at 60fps :3
I added a 32gb ssd since i saved $60
