My Ubuntu server is running Netdata and it keeps throwing alerts about Netdev and periodically Entropy. I have followed the Red Hat guide as best I can but I cant seem to get netdev to calm down.
Don’t know if you found a solution to this over the last 4 months, but I was trying out the new question mark feature and found your post.
Regarding entropy. I chose to use a random number generator called haveged, on my ubuntu server. Try and see if you server’s entropy lever is below 1000 with this command. If it is, you should probably do something about it.
As I mentioned, I use haveged, a minimal resource program. I don’t know if there are alternatives out there, or if there are specific security concerns regarding your use case. In any case, haveged can be installed from the default ubuntu repository.
