Hay guys, firstly I'll introduce myself seeing as this is my first post.
My names Sam I'm from Australia, I built my first PC in year 7 as a project for school (stripping the family PC and re-building it)
I fell out of PC gaming and had a bunch of consoles for ease and convenience but thought "fuck it i need a new PC" and here we are.
The plan was something I could use for gaming, video editing, graphic design and digital art for the missus
The specs ended up with are
RUNNING GEAR
Phanteks Enthoo Primo Ultimate Chassis black
ASUS Sabertooth Z97 Motherboard
Intel Core i7 4790K
2 x Crucial Tactical Tracer BLT2KIT8G3D1608DT2TXRG DDR3 (4x8GB)
Corsair AX860 Platinum Power Supply
2 x EVGA GeForce GTX 780 Ti Superclocked W\ ACX Cooler
DRIVES
Corsair Force Series GS 128GB SSD
2 x Western Digital WD Black 3TB
Samsung 840 EVO Series 1TB SSD
FANS AND ACCESSORY'S
XSPC Twin 3mm LED Kit Green
XSPC Twin 3mm LED Kit UV
Corsair Gen2 White Sleeved Modular Cable Kit
Corsair White Sleeved ATX 24pin for 2nd Generation AX Series
BitFenix Sleeved Molex Extension Cable 45cm White
BitFenix Sleeved 4-Pin Molex Power Splitter White
5 x SilverStone Black 100mm PWM Fan Splitter Cable
Phobya Y-Cable 3Pin to 4x 3Pin 60cm - Black
Phobya Y-Cable 3Pin to 3x 3Pin 60cm - Black
4 x Corsair Air Series SP120 Performance Edition Twin Pack
3 x Corsair Air Series AF140 Quiet Edition High Airflow
2 x Cougar CF-D14HB-G 140mm Green LED Fan
2 x Cougar CF-D12HB-G 120mm Green LED Fan
2 x UV LED strips
WATER-COOLING
XSPC D5 Photon 170 Reservoir/Pump Combo
XSPC RayStorm CPU Waterblock for Intel
XSPC RX360 Triple Fan Radiator V3 Black
PrimoChill PrimoFlex Advanced LRT Tubing Green 1/2ID 3/4OD 3m
Noctua NT-H1 Thermal Compound
XSPC RX240 Dual Fan Radiator V3 Black
PrimoChill Antimicrobial Tube Coil Silver
2 x Heatkiller GPU-X³ GTX 780 Ti Hole Edition Nickel / Black
2 x Heatkiller Titan Backplate - Nickel
10 x Monsoon 45° Rotary Angle Adapter 3/4" OD Green
10 x Monsoon Free Center Compression Fitting 1/2"ID x 3/4"OD White
10 x Monsoon Standard Rotary Accent Disk White
PERIPHERALS
Logitech G502 Proteus Core
Corsair K70 RGB Red
Hyperx Cloud Black and white
ASUS PB278Q 27in PLS LED Widescreen Monitor
ASUS PG278Q ROG Swift 27in 144Hz G-Sync Gaming Monitor
here's a link to my original Build Log with all the issues I had
I'll just do a quick summery here for you all
here we go
so this was the original package with the case, its much larger then it appeared online hahahaha I love the lines and the stepped cable management side with the I/O
a selection of the fans installed, the AF140's got shit canned because this was when it was going to be a air cooled build but decided to have a crack at water cooling
the Z97 saber-tooth, Looks amazing IMO
32Gig crucial balistix tactical tracer 1600Mhz CL8 1.5V
solid PSU
Boot drive for Windows 8.1
The beating heart, I haven't had a crack at OCing yet
First boot with no GPU's, the RAM says it all (:
test fitting the WC parts
the fittings
those water blocks are so bling but heavy as fuck
First boot with the GPU's
Fitting those GPU blocks
CPU water block fitment
dems fittings
leak testing
GPU issues lead to draining the loop and re fitting the GPU water-blocks once, twice and thrice, was about to give up here and just leave them air-cooled
But finally we got a clean boot with both GPU's showing
dirty OC on the GPU's
Up and running
Cheers for getting this far guys, I urge you to have a look through my original build log to see all the issues i encountered.
for first builders I recommend always double and triple counting parts so you don't end up 1 fitting down and having to spend $30 shipping one from the US because that blows and order as much as you can each time so you don't end up having to over pay in shipping.
the case was a dream to work with, there is so much room.
For temp management I have a temperature probe in one of the pump inlets and plugged into one of the boards temp sensors, I have all the fans plugged into the fan hub and that hub slaved to the water temp sensor so it keeps the water and system cool and quiet
The cable management cover Wendel refers to in the video is actually a vertical res mount (the cover with the black plastic next to the MOBO) and was my original choice for the res however mine didn't mount there.
many thanks all, any advice or comments are always appreciated.
Peace and chicken grease.
OzTurkish
