Enough wattage for 770 SLI?
Right, so i've gotten an offer for my current eVGA gtx 760 acx, and for that, and a bit of cash, i could get an eVGA gtx 770 4gb, but i was wondering if my corsair cx750 750 watt psu could handle going 2-way SLI with those
The rest of my system is an AMD 8350, asus sabertooth 990fx r2.0, and a mechanical harddrive, and a SSD
Power draw of a 770 at load according to this is around 380ish watts.
http://www.anandtech.com/show/6994/nvidia-geforce-gtx-770-review/16
TDP of an 8350 according to this is 125W.
http://www.techpowerup.com/reviews/AMD/FX-8350_Piledriver_Review/
380x2=760+125=885
without HDD or SSD
You would need to get a 1000W PSU to power that... If you don't overclock.
What if i only get the one, and overclock that? also would i be able to get a 780 and overclock that?
Yep, you could do that just fine.  I recommend it too.  Single card solutions are always better than two.
Though it wouldn't be as powerfull, but i think that's what i'm gonna go with, since getting a 1000+ watt PSU is rather expensive, at least where i live...
TDP is heat dissipation, not maximum power draw. Easy to get confused.
I should think that overclocked 770 would pull about 250W each. It's only under a synthetic bench that you will see 300W on each card, their maximum power draw, but games are not quite as intensive as synthetic benchmarks. So 750W is sufficient. However, I would recommend grabbing a single 780, anyway. Dual GPU solutions can be troublesome
I totally read those graphs wrong... time to go to bed...
edit: see how the graph says "total system power draw"
I'm doing a lot of that from memory. I haven't slept at all, otherwise I would be equally terrible. I have displayed some rather terrible grammar this morning.
Happy 10.40AM-ish
I'm showing it too.  Thanks for correcting that, I'm off.
Your psu will be fine. Its only in benching etc that you'll see big consumption numbers. You can always grab a cheap watt meter to measure your rig. If you see that it pulls close to the 700 mark under load than maybe look into an upgrade.
I have the exact set up as yourself, I have been considering a second 770 to go SLI and I have a 750 watt, I doubt it should need any more.
