Not to anyone’s surprise my Enermax Liqtech TR4 died as the rest seem to have. Mine may have lasted a bit longer but failed catastrophically in the end.
Just some teardown puctures for your viewing pleasure.
I think that’s one of the worst failures I’ve seen when I see threads about those coolers dying. The only metals I’ve seen more corroded than that are 20 years old cars that have lived up north.
They did suggest a water quality issue, so even after improving the materials for the gasket, which they thought was the only problem, I think the water quality and the heat from the CPU accelerated the issue. High flow rate which Enermax also advertises could also peel at protective coatings if the water was sub-par already.
