hI, I recently purchased an AMD FX 8350 CPU, and the stock cooler in games is up to 65 ° C and 5400 rpm, not needed to say is quite annoying noise hahaha.
I was watching the review made by the Syndicate Tek on Enermax ETS-T40-TB and it seemed interesting for the price and perfomance, but...
Could this be enough cooler for my AMD FX 8350?
I no want for overclocking, i only want maintains optimal temperature at full load cpu without noisy.
i wouldn't see an issues personally it a very nice cooler and should do what you want since your not over clocking but if you wanted to i wouldn't see an issues as well as you don't go to crazy with the overclock. Hopes this helps!
Thanks Casdune for your help, and yes, help me a lot
