TL;DR: bought 21:9 monitor, enabled freesync, all good!
How to test if freesync actually is working?
I can see it is enabled and play games.
Is there a scrolling bar test?
Not having much luck with ufo site and amd windmill demo through wine.
There is a FreeSync test app from AMD. You’ll have to search around to find it though. I don’t have the link anymore.
Those are both the AMD Windmill tool and test UFO I mentioned.
Both are not supported, windmill via wine results in: http://i.imgur.com/HszzRPo.png
testUFO: http://i.imgur.com/HYcbcPV.png
I played some DOOM using Proton, had to stick to opengl as Vulkan causes doom to crash on startup, even with steam overlay disabled.
Doesn’t go beyond 60FPS (monitor can do 144) but doesn’t seem to tear.
