I upgraded my motherboard to Aorus X570 Pro but want to keep using my 2700x for the time being.
However I am unable to find setting in BIOS to enable Performance Boost Overdrive or anything about XFR or so on. I am getting less performance than when I was using B350.
Then I don’t really know if any of this would really matter in my daily usage as I don’t live and die on per minute render times or FPS on games.
However I would just like to know; is it that X570 boards are simply designed 3000 series processors and although they are compatible on 2000 processors, it’s impossible to get optimal speeds unless manually overclocking or so?
I believe that PBO is causing some high voltage issues on idle with the new Ryzen 3000 series cpu’s.
So i suppose the feature is present in the uefi somewhere.
Or you might need to update the uefi firstly.
But of course you could eventually also overclock the cpu manually.
Shouldn’t be that much of an issue since you are running a 2700X.
I suppose that the PBO situation is likely goingto be fixed with future uefi updates.
I’m not sure what the current situation is with Gigabyte boards and PBO.
But Asus i believe is still having issues.
No, at this point in time there is no reason to believe that a Ryzen 2000 CPU should not run with its “best possible performance out of the box”.
However, sadly you can make a pretty safe bet that all X570 BIOSes are probably still very much a work in progress with a few bugs.
I tested an ASRock X570 Taichi with a 2600X and it ran as fast as on an X470 Taichi, however quick memory OC tests were much easier.
@nyankocool
On a different note: Could take the time and look through your BIOSes options if there is a setting to enable Thunderbolt?
Your motherboard should have a 5-pin header above the SATA ports that doesn’t show up in any manual that is intended for a Thunderbolt AIC. However this AIC also needs BIOS support so a physical header on the motherboard alone wouldn’t be of much help if there is no coresponding option already in the X570 Aorus Pro’s BIOS.
Thank you very much!
@aBav.Normie-Pleb Thank you for response. I am presently stuck with pre May 2019 Windows update, comparing to my earlier install, this could be the reason I am seeing lesser performance.
However, practically speaking though; I am having no issues whatsoever regarding performance; could be placebo effect of paying almost 300 dollars for new motherboard, but I kind of feel like everything is a bit snappier.
By the way, I am seeing dramatically lower temperatures with my 2700x in the new mobo comparing to B350 Prime. I did upgrade my stock cooler to cheap Japanese air cooler which should help cooling around 6-7 degrees, (so I was told). But I am seeing less than 40C idle temps, mostly around 34-36C… which is amazing. Even with moderate workload my CPU goes barely over 50 and the CPU fan stays completely quiet.
With previous setup I was idling around 50C, even with the -0.08 undervolt that did help a bit.
I felt default settings in the board were always somehow feeding too much power to the CPU.
Yes, I have checked BIOS and no Thunderbolt. In my copy of the motherboard the “header” is simply solder points, there are no header to plug anything to. But it seems to be connected though. Wan’t picture? Maybe soldering iron and some pins would possibly enable Thunderbolt in future? Oh boy I would LOVE that…
That is very interesting thank you for the Thunderbolt details. To me this suggests that Gigabyte isn’t really trying to introduce TB to AMD platforms
(ASRock mentions TB in its manual for the X570 Taichi, but only offers an outdated first-generation Thunderbolt 3 AIC, Gigabyte by contrast the second-generation AIC with DisplayPort 1.4 but doesn’t support its own AM4 motherboard models (no mentioning of TB in its X570 manual or of the TB Header)
I wonder why TB solder points exist? There is text THB_C under it.
I speculate that the hardware engineers were told to implement Thunderbolt since it has been opened up by Intel for snyone but the marketing douches thought that this was completely unnecessary:
“Why would we make a product with a feature no other AM4 motherboard manufacturer can offer? It has to be enough this year that we switched from metal chunks to real heatsinks with fins for the VRMs on some models!”
There is a different thread discussing this regarding Gigabyte motherboard, there the consensus is that those motherboards without the TBC Header were pre-production revisions and later retail revisions should have the TBC Header.
But your experiences contradict that so maybe give a few details about your unit in that thread:
https://forum.level1techs.com/t/x570-aorus-xtreme-master-was-it-originally-intended-to-have-thunderbolt-support/144835/24
