Hey thought I´d make a post about my latest (and first) pc build. I went with a mini Itx build, because I have limited space in my room, and I needed something I could put on my desk.
Specs:
Motherboard: Asus Z87I-pro
CPU: Intel Core I5 4670K
Ram: ADATA XPG 1600 mHz 8 Gb Stick (single stick so if i need more memory i don´t have to replace any)
GPU: XFX Radeon R9 280X (went with XFX because all other vendors are sold out, because of coin mining)
HDD: Seagate 1TB Desktop SSHD
SSD: ADATA Premier Pro SP900 128 Gb
PSU: Corsair CS650M 80 Plus Gold
CPU cooler: Cooler Master Seidon 120m
Front Radiator fan: Noctua NF-F12 PWM
Side fan: Noctua NF-S12A PWM
Case: Cooler Master Elite 130
Btw there is something wrong with my camera lens so i had to use manual focus, so some of the photos aren´t perfectly focused.
<img>http://i.imgur.com/dC6ESu0.jpg[/IMG]
[IMG]http://i.imgur.com/AVoBmy6.jpg[/IMG]
[IMG]http://i.imgur.com/yrWSmGL.jpg[/IMG]
From the outside
[IMG]http://i.imgur.com/D3hXj4Q.jpg[/IMG]
[IMG]http://i.imgur.com/ZkI1WLY.jpg[/IMG]
[IMG]http://i.imgur.com/PcA6ZRZ.jpg[/IMG]
it was a real hell getting both the hard drive and the side-mounted fan in here, but I got it in the end. I could have mounted the hard drive in the 5.25 inch bay but I wasn´t comfortable with that because a lot of hot air gets exhausted there.
[IMG]http://i.imgur.com/vHcbQPh.jpg[/IMG]
[IMG]http://i.imgur.com/41Ky8BL.jpg[/IMG]
a glimpse of the hard drive
[IMG]http://i.imgur.com/jEpuNUX.jpg[/IMG]
you will notice I have removed the side 80mm fan, that´s because the daughterboard of the Z87I blocks it so that it actually keeps more hot air inside more than what it is dissipating.
[IMG]http://i.imgur.com/LonGyzM.jpg[/IMG]
[IMG]http://i.imgur.com/eAlR1dO.jpg[/IMG]
Cooler Master actually recommends having the psu fan facing down if you have watercooling, because of the limited airflow around the motherboard. I tried it but switched to having it facing up instead, because it was getting hot enough to cook eggs on. Also with my side 120mm fan I think I have plenty of airflow.
[IMG]http://i.imgur.com/Cpd36Sb.jpg[/IMG]
[IMG]http://i.imgur.com/SIbcmrT.jpg[/IMG]
[IMG]http://i.imgur.com/Py9S7yB.jpg[/IMG]
All in all i´m really happy with it, the water pump could be quieter, but i don´t have any other complaints. Right now I got my CPU overclocked to 4.4 GHz I did get it to 4.6 with stock voltage but I feel more comfortable with a little lower of an overclock. Also at 4.6 I could not get a native cache ratio but I can with 4.4.
Also I am using a Dell U2212HM monitor (I like IPS), a Steelseries 6GV2 keyboard, a Steelseries Siberia V2 headset and a Gigabyte GM-M6880 Laser mouse (got it for cheap on amazon) with a Steelseries Qck mouse pad.
I think that was all thanks for reading, also i could use a cool name for it.
-Joakim Andersen
