Ehhhh.. new case fans smells?
I just got a couple of Bitfenix Spectre LED and after I installed them, my room started to smell too much of new computer, (Electronic smell) Does anybody have an idea what could be the cause? Could it be some sort of  excess oil/lubricant getting burned off? Getting a bit nervous tbh.
naw, it's prolly the extra CFM that u never had before....
Fluid dynamic bearings shouldn't leak so I'd make sure they aren't. If it smells like hot plastic you shouldn't power on your computer until you've found the source and fixed the issue.
