eGPU not showing up
Hi all,
I’ve got an interesting problem on my XPS 15 9570 where the eGPU shows up on my laptop when using the provided cable (18in, most likely passive), but when I use a longer cable (6ft, active, link below), the device frequently will not connect properly.
6ft Cable in question
The eGPU in question is the Gigabyte Aorus Gaming Box 1070. (with the included 1070 in it)
I get the following in Device Manager when the connection fails.
Additionally, I get this message when it’s plugged in:
I’m far from a Windows pro, so any pointers would be helpful.
Again, the device works perfectly fine with the shorter cable, so I’m think it’s something about the long cable that it doesn’t like.
I would question the quality of the cable. I don’t think the length is an issue necessarily.
That was my first thought, obviously, but you’d think that when you spend $60 on a cable (harkens back to the SCSI days, damn), you’d think you get something that works.
I just got a “beta firmware” from Gigabyte. I’m gonna see if that helps. :confused: I really need this longer cable. :crossed_fingers:
Welp, now plugging the short cable in doesn’t work. :anger:
Might be a bad unit.
It’s gigabyte, all of their firmware is beta
/s
I’m still salty about my last motherboard.
LOL true.
Here goes:
Okay. Rebooted, plugged it in, nothing. Unplugged, rotated the connector 180 degrees and tried again, got the 1070 showing up.
What a strange situation. Damn thunderbolt is awesome, but it’s also apparently a bit buggy.
I think that is the usual situation when you have a protocol that is meant to be internal (PCIe) and is not hardened against anything and push it through some battle-hardened thing (USB).
Hah yeah. I guess that’s true.
This thing’s been kicking ass for the last hour or so though. I think the beta firmware is working. It’s been transcoding video for a project for the last hour or so and loving it!
