Howdy Everyone,
This is a new one for me in my Linux only journey. I bought an 5800X3D after a long time of running my 2700X. To cut to the chase here, I had to update my bios, I followed the steps laid out in this post here and it worked without a hitch, for the most part lol.
After I got all the new hardware installed, I swapped from my Windows drive which I was using for the BIOS updates / EC FW stuff, to my Artix install. However, even after disabling CSM, it will not boot into my artix install unless I boot from the Artix live CD, OR, I copy my /boot/EFI/grub/grubx64.efi to /boot/EFI/microsoft/boot/bootmgfw.efi
To add to this, windows WAS configured at one time to be formatted for GPT and not MBR, not sure if that changed with windows updates after I used it for the first time in years.
I am currently searching through my own notes since I am pretty sure this is something I encountered a long time ago (6 years?) after I stopped dual booting.
EDIT:
To add I did turn CSM off on my motherboard, I think its likely something here got massively biffed during the mobo updates. I have also turned off secure boot at this point as well.
