Editing/Gaming Machine (1st Build)
Hello all I am planning on building a fast editing and gaming machine. I use Adobe Premiere and and Adobe Media Encoder and for gaming I want to play on high settings on games like Titenfall and BF4. My budget is around 1600 US dollars. I don't plan on overclocking so I don't really need a cpu cooler. This is what I have so far: http://pcpartpicker.com/p/3bEMW
Thanks
Looks good, but I would get a CPU cooler. I couldn't handle how loud the fan was on my 8350.
Looks pretty good.  I would pick up a Cooler Master Hyper 212 Evo aftermarket CPU cooler, as the stock AMD one is a pile of poop.  If the Hyper 212 Plus is cheaper, that will work too.  There's only a 1-2c difference, with the Evo usually having what little advantage it has over the Plus.
Ok thanks I'll go add that to the list.
