Looking for some critique of my new workstation build:
http://ca.pcpartpicker.com/user/nem2k/saved/XJLFf7
Does it all work together? Is there anything that you would change around?
My budget is $2500 (CAD) for the parts listed in the link - this must include both tax and shipping costs (to vancouver, canada). There is no cpu cooler in the list because I have a custom water loop planned. So $2500 for the machine minus the cpu cooling
Water cooling loop can be found here if it helps: https://teksyndicate.com/forum/cooling/water-cooling-loop-critique/186430
I will be using this mostly as a compositing and video workstation, with some 3D modelling/texturing at times. Programs include Nuke (primarily), Zbrush, Maya and Mari
The goal is to try to minimize rendering times and maximize viewport performance
All parts (cpu, gpu, ram) will be overclocked. Would prefer to stick with the i7 series instead of going xeon. And I will be reusing the SSD in my current computer as a cache/swap drive (on top of the SSD and HDD in the list above)
A few questions I have:
1. Is the 750w PSU enough to power this machine?
2. Are the quiet edition Corsair fans enough for cooling? CPU will be cooled via water
3. Should I jump back a gpu generation and grab a 6gb card to handle larger texture files? workstation cards are out of the question as they eat heavily into my budget (none of my programs are particularly gpu intensive anyway)
4. When do you expect DDR4 prices to begin dropping a bit? Are we looking at a few weeks or a few months?
