Editing and Animation
I have recently upgraded to a GTX780ti from my 670 4gb edition and i now need a amazing motherboard and processor to go with my graphics card. i have a price range of about £200 for the processor and about £100 for the motherboard. i plan on using all the adobe programs and i also use cinema 4d. i will need it to play games fairly well as that is what i record and upload to you tube. the games will be minecraft portal and simular steam games but i don't really play loads of games.i hope this is all the info you need and if there is anything more just ask me.
i was thinking something like this would  serve you well, because you want to record wenn gaming, and then the extra cores on the FX8350 can come handy.
http://uk.pcpartpicker.com/p/Zn7D
i was thinking that intel i7's were better for editing?
yes basicly they are, but they are also 100 pounds more and the diffrence isn´t that big.
an i7-4770K is 233 pounds, if you got 300 to spend then there will be not much left for a decent mobo. but if you can stretch the budget then a i7-4770 (k) and a Msi Z87-G45 gaming is a good combo. But the FX8350 isn't bad.
If i had a dime for every time you recommended the sabertooth and 8350 i'd be a millionaire...
Mystery knows what she is talking about
I use the 8350 for 3d rendering in cinema4d as well as the odd things in adobe premiere and it is more than adequate.
Spend the money you would save on a bigger ram kit (if you work with big scene files being able to fit everything in memory speeds up things massively) or put it towards an ssd.
It is a good combo.
indeed ☺
Ya i just found it funny how much she loves the combo over any other possibility. Don't get me wrong it is the best 8350 & motherboard combo available but i think she may love ASUS a little to much, not that its a bad thing with how good there products are but still.
i think i will go for the intel version just because i heard some bad reviews about the amd one burning out in about a year or so and i could wait and save up a bit more to get the i-7
Fair enough, you will get those sort of horror stories with everything though
and its largely down to the user pushing it past it's tolerances rather than the part in question.
Just so you know, i am coming up to about 9 months now with my 8350 + sabertooth and it is perfectly fine, will let you know if it goes *boom*.
it won´t boom ☺
I know :)
It's my poor attempt at humour.
I have been running this thing overclocked (4.6ghz) for roughly 9 months now and I haven't had a single problem, heat and voltages are within acceptable parameters.
