Would memory errors in Linux show up in the kernel message log (dmesg), in the form of it complaining about ECC being disabled?
I keep seeing stuff like this
[ 481.556354] EDAC amd64: Node 0: DRAM ECC disabled.
[ 481.556355] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
(Note that use of the override may cause unknown side effects.)
[ 481.556359] EDAC amd64: Node 1: DRAM ECC disabled.
[ 481.556359] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Sometimes just at boot, which I suspect is a normal information message, but sometimes much later, like the messages above coming up after almost 500 seconds of uptime.
Sometimes the come up over and over and over again, like spam.
I have a 64gb kit (4x16), Corsair 3200 DDR4 NON-ECC clocked at 3000mhz (can’t seem to get to 3200), running 1.385 volts. Board is a x399 Designare, CPU Ryzen Threadripper 2950x
I’m about to add another four sticks, same thing 64gb kit.
Wondering if I should drop to single user mode and let memtest run for a while?
If these EDAC ECC messages are not signs of a memory problem, is there a way to disable them?
