http://www.ebay.com/itm/49-Feet-Ethernet-RJ45-CAT5-CAT5E-LAN-M-M-Network-Cable-/370489830465?pt=US_Ethernet_Cables_RJ_45_8P8C_&hash=item5642ea2c41
Came across this cable, is it any good. Why is it so cheap? Thanks
Simple answer is yes it is completly fine and it is so cheap because you can get a 10 footer for a couple cent's
Yep, it's fine.
Signal loss isn't an issue with these things until 200 Meters.
I actually bought a 25 foot cable exactly like that. Works very nicely!
Thanks guys, another question how does AWG play in to this. For example, this is flat CAT6a.
http://www.ebay.com/itm/15M-RJ45-CAT6a-Flat-Ethernet-Patch-Internet-Lan-Network-Cable-Wire-Cord-Blue-New-/130695122141?pt=US_Ethernet_Cables_RJ_45_8P8C_&hash=item1e6e094cdd
Also CAT6a is backwards compatible to to CAT5 right?
You shouldn't need to worry about AWG as there shouldn't be enough current going through those wires to matter what gauge of wire it is
Ok thanks guys!
Cat7 cable is at a reasonable price on newegg.
In Canada it's about $30 with shipping. In America it's $17 shipping included.
A 3 foot Cat5e cable at the physical store of Walmart is about $13.
"Save Money, Live Better" :D . Thanks for the help guys!
