Easy way to remove watermark from image without losing quality?
My computer was crashed and some of the important images were gone. Fortunately, I have a backup on my website remote server. The problem is that these images have website logo on it for protection.
Is there a simple way to let me remove watermark from image without losing quality? There are about 200 images to be processed.
Thanks
Do you have an account & direct access through that account to those images? In my limited experience you usually have access to the full resolution image without watermarks.
If you haven’t altered the drive that crashed you also may well be able to recover the images with basic data recovery software. I’ve done it before.
Photoshop if you were familiar with it. Otherwise, AI image editor is more suitable for beginners as you only need to enter the prompt to remove watermark from images.
If its a generic watermark, like slightly gray words or logo or something, hop into your favorite photo editor of choice, you’re gonna be doing a lot of clicking.
Isolate it, match it to how it is in the image, then subtract (or blend it out) it from the image. This is something you can automate if you’d like, but that hinges on the watermark being consistent in each image, and also not overly complicated.
I’m sure PS has turned this into a one-click solution, saving dummies like me the time from the way it use to be done.
Krita can help remove common watermarks. It works well for small marks, especially when the background is simple.
To remove a watermark in Krita:
Using the Clone Brush to blend it with nearby areas, then export the image as a PNG. To remove watermark from image without losing quality, keep the original resolution and remember that complex backgrounds may be difficult to restore perfectly.
For the best chance to remove watermark from image without losing quality, edit carefully and save your final image as a PNG.
A few days ago I wanted a watermarked image for a PowerPoint slide, so I tried Microsoft Paint. It has no one-click watermark remover—I used the Select tool to box in the watermark, then covered it with Fill or nearby colors.
The catch: the watermark shouldn’t sit on complex textures, or the patch will look obvious. Done this way, you can remove watermark from image without losing quality, since you’re only editing pixels, not re-compressing. Just save as PNG or BMP, not JPG.
For simple backgrounds, you can remove watermark from image without losing quality—but for complex ones, don’t force it.
