Ah, that’s not a terrible solution, I’m just a bit wary of that power-on time.
Yeah me too, but they only had 68 power on/off cycles.
So these things were likely thrown in a rack somewhere and just rebooted a handful of times a year.
I’m sure I could get squeeze at least two more years out of these things.
SAS drives are like fucking tanks.
Yeah, that’s a much better indication, I’d say.
Probably.
Typically, it’s power-cycle and model that are a better indicator than temp/power-on time.
My other drives have Oracle branding
Alright, so the drives are at ~10% complete. So it will take about 2.5 hours (3 hours total) for the drives to complete formatting.
We have the same eBay kit. I have yet to actually format the drives and configure. You overwrote the pre-loaded FreeNAS for Fedora?
Yes I did.
Long story short, they advertised FreeNAS 11, but mine shipped with FreeNAS 9.4. So after installing the latest version of FreeNAS I just had constant issues.
For some reason, it would never fetch updates and always fail. So whenever there was an update to the train I had to reinstall manually.
I really liked having the web gui for such a thing but it wasn’t worth it.
So I installed Fedora 30 Server and manage it now with Cockpit and the CLI. I got ZFS on there too. Works great, and since I’m a bit more familiar with it I think I’ll be able to hack around with it better.
Damn, so that eBay vendor put out bad info and the drives are not even checked from the looks of it.
I booted mine up once (forget why, maybe a before/after noise test with my plexiglass setup) but didn’t check version, and noticed one of the drives had a blinking led… Uhhg.
Maybe? I’m not sure TBH. However, the BIOS was updated and the drives it shipped with were fine. Literally, everything else checks out.
The drives I am currently having issues with I bought a few days ago from a different seller.
By chance did you have exec turned off on the root dataset of your pool?
Did you buy from uxs?
The formatting completed sometime in the early morning and I am sad to say it did not work.
The drives still show up as size of zero and I was unable to reformat with 512 bytes. My drives are from 2011 though.
Guess I’ll contact the seller now.
Yeah, I’d do that.
In all likelihood, you’ve got the lba 0 issue, but it’s honestly not something you should have to deal with out of the box.
Yeah, I got the drives on the 27th. It would be different if I got these for free. But yeah I straight up bought these drives that don’t work out of the box.
