Hello. First, an obligatory “I’m not sure if this is the right place to post”, but more importanly, I apologize for immedately asking for help without contributing anything useful myself.
So, in what I now realize was an unwise move, I got an AM5 board. Namely, the Gigabyte B650 Aorus Elite AX (just typing this name out kills my brain cells). And while It does kinda work, the noise it makes has me worried it’s not going to be the case for long. Basically, it does 2 things: the electrical buzzing sound, which is more or less constant, and an intermittent whistle/whine sound (which is, I guess, the infamous “coil whine”).
There are 2 things that seem to affect the buzzing noise in a tangible way: disabling C-States reduces the frequency by quite a lot, to the point where it’s almost gone (disabling power-saving doesn’t sound like a good idea, though, especially since it makes the CPU run about 10°C hotter), and, weirdly enough, playing some music through the USB DAC (using a null output doesn’t do anything, however, which probably means it has to do with the USB port/controller power delivery, although disconnecting devices or using other USB ports doesn’t seem to make a difference). On the other hand, running a compile job on all CPU cores makes it into almost a hiss, though fans running at 100% doesn’t make it easy to spot.
The whine/whistle, though, seems almost random. This one could be heard for a few seconds while watching a video, or typing some text, for example. Though, after doing another smart thing ™ and updating the BIOS from F1 to F3b (what could go wrong), it occurs much more often now. Trying to compile something, for example, causes constant (and extremely loud) whistling noise. The only theory I have here, is that’s it’s a side effect of enabling RAM’s XMP profile (didn’t work on F1, hence the update).
So, after all the incoherent rambling, I guess the question I have is this: how worried should I be that this thing explodes (and takes something plugged into it with it)? It did somehow survive a full Gentoo install, so it probably has some life left in it, but after that BIOS update I’m not quite sure I should be even turning it on.
Edit: couple of things I forgot to mention: I’m currently running off an iGPU (all PCIe slots are empty, so it can’t be a GPU coil whine), PSU is be quiet! dark power 12 pro 1200w (what’s with these names), which is overkill, I know, but it has a lot of power to spare and (should be) of pretty good quailty.
