DVI to VGA or DVI to HDMI, Which is better quality?
Title says it all, Would I be better off using a dvi to vga adapter and then a vga cable or a dvi to hdmi adapter and a hdmi cable.
HDMI. VGA is shitty old on its way out tech.
hdmi is digital, vga is analog, use whichever you prefer, most people will say digital
I feel like VGA has been on it's way out for FAR too long, haha.
Yeah to be fair, if you already have the VGA cable, but don't have a HDMI cable, I wouldnt go out and buy one unless you're going to be running some ridiculously huge resolution as VGA can only go so high, I forget how high exactly. But yeah, if you're only going to be having a normal resolution VGA will do just fine.
But if you have both then yeah go for HDMI, it can also do sound if needed.
