DVI I dual link to VGA not working
Im trying to use an old monitor that only has a VGA port. When I use a DVI-I dual to VGA adapter it isnt working.
I believe only one of the DVI ports will work with a passive VGA adapter so try the other one if you have not.
Adaptive adapters are much better than passive adapters.
