DVD Ripping
Hey guys,
Just wondering what your opinions are regarding the best programs/methods of ripping DVD's.
I'm looking for a method that will keep the quality of the DVD's but is still fairly quick. Also, I'm assuming that the file sizes should not be more than a few gigs as they aren't high definition, is this a fair assumption?
Thanks!
Make.mkv can be used to make DVD rips while still maintaining the original quality of the DVD. The files are usually around 4.5 GB per DVD, roughly the capacity of the DVD. This doesn't really belong in inbox.exe .
Make.MKV is great, and you're right, this is not an Inbox.EXE question.
