I Made a DL dvd last year and It has LOTR 2&3 extended blu ray edition on it. I still have the DVD. But I have no clue what program I used. I could go mad. I have been looking for the past hour. I have a screenshot of the main screen. The movies play next to the title. I had a dvd called stoner flix at one point that had 10 movies on a single DL and it worked on every dvd player
So basically you made a data DVD with encoded video files on them? Do you remember if they were XVID or X264 files? Most DVD/Blu-Ray files will play Xvid .avi/x264 .mkv files that have been burned as a data DVD.
You could give InstaBurner a try. Icon looks like this.
I have no clue where I downloaded it from, so be cautious. (If you know of a way to do so, I will send the files to you)
Other than that, I don't know. Good luck!
