Dust In PC
What's up my tech buddies! Aight so I got my pc in my room on top of my computer desk and I'm still have a lot of dust get into my case. Well its not "A LOT" but enough for me to notice. My components are also getting a layer of dust on them as well. I got two 230mm fans(one in front and one up on top) along with a 120mm attached to a radiator. The front fan is blowing air into the case and the other two are blowing out. The case doesn't have dust filters but it has room for one in front and I can install an other fan on the bottom of the case. I use canned air to clean it but idk how to clean my components. I also would like some ideas on how I can reduce the amount of dust going into my system.
Thanks Homies!
DoDaDragon
P.S - I try to fold my clothes away from my computer, I know clothes gives off lots of dead skin cells and lint.
Oh forgot to show a link to what I got, if it helps
http://www.coolermaster-usa.com/product.php?product_id=2963
aim for high pressure (more intake than exhaust), get dust filters
as for cleaning most things can be blown off, when i get dust really stuck to my fans i just wash them in the sink with water, same could be done for heatsinks (really as long as the water's clean and it fully dries you can wash everything)
Aight so adding another intake will add more pressure.
But I'm trying to get the layer of dust of the PCB on my GPU, any tips for that?
And thanks for the INFO
Compressed air
Cotton swabs for the nooks and crannies
If those two don't work, some rubbing alcohol on a towel/rag/whatever can work, but make sure it's completely dry before powering it on again.
Compressed Air, dry paintbrush. I have the original version of the 932 and I have a cat.. Bounce sheets make a good filter for a temp measure and make the pc smell nice, but that gave me a headache after a few days. I ended up buying some really fine mesh window screen for the side and bottom and AC filter foam for the front and the 5.25" bay covers. Now if I can get my wife to quit smoking ...... but that's a fight I'm not winning any time soon.
Hardware stores for PC filters YAY.. still wondering why the HAF932 never came with any filters, the Ammo533 did and it was older...
I use a leaf blower (just rember to hold any fans before blowing air at them)
I used to have access to an air compressor.. I miss those days.
