Dust-free build
Hi everybody, this is my first build and i would like to build a medium-high level computer that will be used for a bit of everything and that won't be upgraded very much, but with a special consideration for dust. This is what i picked: http://it.pcpartpicker.com/user/bennyhillthebest/saved/3bb1
For the case, which in this situation is probably the most important thing, i think i'll go for the Arc Midi R2 with the smoked glass on the side. I'm no expert but this case seems dust-proof with all the grids covered with dustfilters, and i know i will have to apply a positive air pressure into the pc, so with two fans in the front as intake i should be good to go, right?
Thank you for your help and Logan, if you're reading this, please consider to do a video with all the best dustproof pc cases or an "how to prevent the dust to amass in your pc" video, because i found that the soundcard and audio quality videos are really interesting and i think dust could be also an interesting subject :D
Excuse myself if there are errors but english is not my mother language
It looks good but remember that nothing can be 100% dust-free! You shoud not have any problems whis dust until quite a long time i thik! So have fun building!
Just remember to keep case pressure positive and you will only have to thuroughly clean maybe once a year
