if you have a duel monitor set up, would first person gaming be a bit weird due to the monitor boarders?
is it possible to assign one monitor for the game and the other monitor used free to open applications for example facebook, skype, youtube etc at the same time?
need help as i am planning on doing a build and wondering if it is worth it. ( saves money too )
You can use a second display for other applications, whilst you use the first for gaming.
If you want to play a game on multiple monitors, you will need three monitors for surround. Otherwise, the centre of your field of view will be between the displays.
ah right. so i would be able to have a game on one monitor and and say facebook on the other monitor when the monitors are connected onto one GPU? unless i enable full surround taking up two monitors. yes? just clarifying. would it decrease the frame rate on the game if i did this?
With applications like Facebook, it won't have any real impact on your GPU. Probably your CPU you should worry about. Don't have lots of programs/pages open in numerous windows, for the sake of it.
cos im also planning on getting an asus radeon HD 7850. would that GPU cope with what i am wanting to do?as well as a intel core i3. would that be able to cope with mid intensity gaming such as battlefield 3 or assasins creed?
Bah, Don't listen to him, run ten windows of minecraft, 3 facebook pages. and just for good measure make sure you have 42 copies of the teksyndicate website open at all times.
(I'm joking of course, most modern cpus can handle many webpages open and playing games, the only thing you might want to watch out for is ram usage with many windows open.)
Seems Mich has entered the competition for budget builds. I must admit, I am not particularly good with small budgets. You should consider the FX6300 (AMD), it is the same price as the i3. It's not unlike newcomers to favour Intel, but you would be silly to go with Intel with your needs.
And BTW OP, that 7870 XT runs like a 7950. This will boost performance beyond your GPU/CPU configuration. Well worth the money.
Edit: if you do not need the OS, you could boost to an 8350. Then you only need to upgrade the GPU at a later time, and you've got yourself a 4 year rig.
