Good Day everyone,
Linus and Anthony showed in one of there last videos, how to setup an “side-by-side VM - 32:9 Monitor”
This is a great idea and something that would fit perfectly in my wish PC
So I want to create a “plan” for my future setup; and because I have fun doing this, I created a diagram with draw.io
I think this makes it easyer to understand what I want to built:
What I expect from this:
- More Secure with VMs (almost no added lag or greater performance impact ?)
- Easy to update, upgrade and replace parts and software
- Fast i/o with programms and games and Temp-files on SSD-Raid (only through lan to PC) (Internal connection possible ? PCIE-to-PCIE ?)
- Semi fast but very reliable HDD-Raid for backups and finished projects and Media (20 TB accessable 40 TB in total) (Share within the same Wifi as router ?)
- Stream one VM to TV (toggle between or atleast Windows only) (Miracast ?)
- Ofcourse the display (and a software to share keyboard and mouse) does all the magic, bringing it together (I just HOPE this is reliable enough for day-to-day work, gaming and fun projects)
- a price around 3500-4000€ + Display (Therefor the “plan”; buying the PC first, than storage, than server, than display ?)
Dreams:
- Get a X68000 Case and fitting everything perfectly, a similiar modern case, or DIY!
So, would this work the way I think it does? Are there any big misconceptions on my side? Or do you think this would be stupid because …?
What’s important: that it works in the end
