Dual Monitor Woes :/
So, the problem is when I switch a video to full screen, about 7/10 times it will swap to the second monitor. When I exit the full screen mode the browser also is switched to the other monitor.
Just curious if anyone else has had this problem and if anyone knows of a way to fix it
It's suppose it's not that important, but HOLY SHIT IS IT IRRITATING. (it really starts to get to you after a while lol)
Side Notes:
They are both different sizes and models.
Both are connected to my GPU one via VGA and the other HDMI.
(Don't know if that's useful or not)
Any help is very much appreciated. Thank you! :)
I have a pretty similar set up from the sounds of it. Primary 1920x1080 HDMI screen and secondary 1440x900p VGA screen. I watch and play everything on the 1080 screen and watch  lot of Netfilx through the browse but I have never had this issue you have pointed out. The second screen is for TeamSpeak and Foobar and that sort of stuff. If it helps I watch Netflix with the other screen off. Physically with a switch on the back of the secondary monitor.
