I don't see a spot for monitor questions, This looks like the best spot.
I need to buy a dual monitor stand with monitors for a coworker, Thinking 22" with display port.
Where is the best place to look for this combo?
Display port would be something to consider for the monitor itself, not the stand. What kind of budget are you dealing with? What level of articulation do you need from this stand? Should it have a baseplate or a clamp?
She wants a desk clamp, Fairly basic is fine. She will be in the front office so it can't look cheep though.
http://www.ebay.com/itm/191262008432?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/131137324015?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Those look nice but a bit more than we were wanting to spend.
I ended up going with http://www.newegg.com/Product/Product.aspx?Item=9SIA3BG14X7420&cm_re=monitor_stand-_-9SIA3BG14X7420-_-Product
I haven't gotten it yet though.
