I have a DVI and a VGA monitor plugged into my GPU. The VGA goes through a mini display port to VGA adapter. Every time I start up the computer, only the DVI monitor works so I have to unplug and plug in the VGA in order to get it to work.
I am wondering if there is something that I have to do to get the 2nd monitor (VGA) to work on startup. It might be that because I have to use an adapter, windows does not detect it for some reason.
