Dual GPUs
I was wondering about cards like Asus Ares and Mars cards that have Dual GPUs on a single card. Should ignore these and instead put more money on a single gpu card? I was thinking of getting one for an itx build.
if its a card like the 760 mars then its worth considering if the price is ok (meaning well below that of a 780ti) >> http://www.techpowerup.com/reviews/ASUS/MARS_GTX_760/
Ideally though a single gpu is preferred just for the driver side of things etc. If your itx case could accomodate a mars 760 then it sure as well will handle a gtx780 or 780ti in which case will be a better option imho. It'll consume much less power and output less heat.
I know I can pay  a hundred more and go for a 780ti, do dual gpus on a card really come with such a headache?
The one problem that I have with cards like the Mars is that it is often cheaper (as is the case with the Mars) to get two of the cards which it combines instead. That isn't an option for a mini itx build though. Honestly, it would be a tough call in that price segment. The Mars, the 780 ti and the 290/290x are all options to consider. Also think about power draw between teh cards (if you care about that), noise, and the resolution that you will be using with this card now and in the future.
Well I have a spare Corsair 560 bronze psu that I'm planning to use.
What resolution screen/s do you plan to use btw? You may be better off with a run of the mill 780. Even a non-reference r290..
I think you mean 650w psu as well....   :-p
Truthfully The Only Reason you should Consider looking at a Dual-GPU card is if You are building a Insane Mini-ITX Build. Because Lets Say for example the 7990 the Dual 7970 GPU Card. It was Great an everything. the heat output was a bit nuts and one can argue correct me if im wrong, but the card was loud at least at different times of use. also 2 Seperate 7970s in Crossfire Outperformed the 7990.
If you dont want to deal with Crossfire issues and SLI issues go with a Single GPU. because you don't have nothing to worry about. now you mentioned the ASUS mars 760. if you are spending that much on it. you can just get an R9-290 or GTX 780. they are both good Single GPU Cards. and less headaches.
Personally there is nothing wrong with DUAL-GPU's I personally Like them. you do indeed have to make sacrifices. but you also have to take in the headaches that comes with using a Dual-GPU, Crossfire issues and SLI issues. because neither is perfect. but if you can tolerate them there is really nothing wrong using a DUAL-GPU.
I was planning to use it in the living room with the 47 inch tv.
Then go for it. like i said there is nothing wrong using Dual-GPUs just take into consideration that SLI and Crossfire does have issues in games. they aren't Major or Game breaking but they are tolerable. and can be annoying
Thank you guys I'll give it more thought going down when I start buying the parts.
.... So 1080p then.
