One last thing
I’ve gone through a “few” heatsinks in getting my build done
I have found that some heatsinks have really stiff springs on their torx screws and others have looser ones.
Holding the heatsink in your hand, If you can’t depress the screw inwards against the spring, slightly, then that spring may be too stiff, which causes at the very least grab/engagement issues
