Dual channel kit
Can i use two dual channel kits for my ram setup?
in the middle of ordering parts for my pc gaming rig.
and am looking to purchase kingston hyper x 1600 (2X8GB)X2 dual channel kit.
but is a dual channel kit only good for a two module ram set up or is it manditory for my to go out and buy a quad channel kit?
Only get quad channel if your mobo and cpu supports it. If not 2 kits is fine just make sure to slot them in the corresponding slots.
what do you mean corresponding slots?
it'll be in your motherboard manuel, what slots to populate first/ in what order
generally it's every other slot example:
kit        kit    kit     kit
1         2       1      2
stick   stick  stick stick
1        1         2       2
though don't take my word for it try and find your motherboard manuel, if you tossed it you might find one online
though if i understand correctly you're getting 32gb for a gaming pc? why? i wouldn't even recomend 16
Yea like if you have color coded ram slots. Lets say 2 are red and 2 are green. Put kit 1 in the red slots and kit 2 in the green slots. But you manual will tell you which dimms run in dual mode if they are not color coded.
I would recommend 16, just no more. After that, it's pointless for gaming alone.
