Hey so I dual boot Fedora with random distros, ultimatley I found that ubuntu works best currently, I’ve had some luck with a couple other, sort of kind of, when in Fedora if every drive is mounted and I run
sudo grub2-mkconfig -o /boot/efi/EFI/fedora/grub.cfg
this command breaks manjaro, centos and pop os! boot, but not ubuntu
I’m wondering if they’re is something that can be done?
I want to just have 2-3 ssds what I can continually install distros and just have one distro manage the bootloader.
I like Fedora’s grub 2 it’s made of steel, never breaks.
I’ve been in a constant study of distros, trying to find one that can run Davinci Resolve with AMD Polaris/Vega, run makemkv and detect and install firmware to my blackmagic intensity pro 4k.
Fedora/Ubuntu can run hacked versions of resolve, I’m crossing my fingers that Ubuntu can get my blackmagic intensity Pro 4k.
I’m not sure how to get makemkv working on Fedora, I also need to check out Centos 8 and Centos stream. If they use Dnf, Davinci Resolve should easily work with Rocm, still unsure about makemkv on rpm distros.
The killer for Centos 8 and maybe even Fedora 31 is 32 bit as still need dxvk/lutris/steam
If anyone has ideas how to dual boot a bunch of distros let me know also if anyone has tried Centos 8, do you know if it can run wine/lutris/dxvk?
Thanks
