DT 770 vs HD 558
Hey.
I would like to get a pair good headphones. I have heard that the Sennheiser HD558's are good, and that the beyerdynamic DT770's are good. I do not have anything other then my shitty onboard sound.
I have Cerwin-vega speakers so i dont want them for the dubstep lisening, but more for gaming and everyday use(Youtube etc.) I want them to be comterbel over long time, open for other suggesjons. i dont want them more exspensive then the DT770's.
Thx :)
Well, I have a pair of DT 770 (80 ohms). They are my only headphones, so I can't say much in terms of comparison.
But anyway, they are nice for gaming and everyday use (and music, of course). Their bass quantity is not nearly as high as I thought it would be from reading reviews (especially user-reviews).
The bass is very tightly controlled, the punch is good, it can get very deep, but there isn't a whole lot of it. So if you aren't using them for dubstep (where you'd want high bass quantity I assume) they should be great.
I tried mine with my iphone just now, without using an amp, and I could turn the volume up all the way up without it being uncomfortable. That's just me of course, but I'd have to recommend the 32 ohms if they aren't gonna be amplified, just to be sure you wouldn't run into problems with the volume.
I mostly listen to electronic music like Daft Punk, Justice, Hotline Miami OST, and some brighter stuff like M83 - just to give you an idea of where my recommendation is coming from. I also use a Fiio E17 DAC/Amp though.
To me they aren't hugely comfortable. The head band is a bit hard on the top of my head, but that might just be an issue I have. They also don't isolate outside sound a whole lot.
